sort date
 Hi all ,
i am having the dates like 5/29/2018 in array ( month / date / year ) [ reading from the access database ]
i need to sort the dates in a correct order . used sort array option , but not getting in a right order. pls, see attached image here .
any other options?
(2,930 Views)
Its always good to share code(VI)/Code snippet, Nothing can be understood by attaching image of FP.
(2,929 Views)
Try this, May be others can suggest easy conversion.
(2,923 Views)
They are ordered as strings. You need to convert strings to Timestamps before sorting, using Scan From String with format string %<%m/%d/%y>T
Paolo
(2,921 Views)
(2,885 Views)
Easiest way if you have control is to start with dates in ISO 8601 format.  Then you can just remove the "/" and sort as numbers.
Reference: https://xkcd.com/1179/
(2,874 Views)
My solution is similar to Paul's.  It just avoids the conversion back into a string.
GCentral
(2,859 Views)
