03-03-2009 05:30 AM
Hello LV users,
I have a VI that is used to initialize some experimental equiptment. It passes on a cluster of ten or so numerical control DBL integers as parameters. Everytime I open the programe the values are reset back to zero and I have to enter the values back in. Is there any way to set default values for the controls so I do not have to change them everytime I open the program.
03-03-2009 05:31 AM
Enter the number you like in the control. Then right click the control and choose "Make current value default".
Mathan
03-03-2009 06:13 AM
Wowden,
If you want to set default values for multiple numeric control's in your cluster in one go,
-Type in the desired default values
- Right click on your cluster, browse to 'data operations'
- Choose 'Make current values default.
Similarly, if you need to set defaults for multiple clusters or multiple controls on your front panel,
- Choose 'Edit' in the menu
- Choose "make current values default' (This sets defaults for all controls/constants etc. in one go)
