09-05-2005 01:44 PM
09-06-2005 03:48 AM
09-06-2005 03:27 PM
09-06-2005 04:34 PM
I 'm doing one channel smapling!
only one channel needed !
09-06-2005 06:28 PM
Hi Fenny,
It may help if you could post your VI, as I am a little unclear as to what you are trying to accomplish. If you are attempting to perform a single finite acquisition of 2500 points, then you should not need to adjust the buffer size. For the finite case, the buffer size needs to be only as large as the number of samples you are trying to acquire (DAQmx should set this for you automatically), and I would not expect that you would see this error. From the description of the behavior you are seeing, I suspect that you are setting up the acquisition to be a continuous acquisition. In this case, it would seem as though you were not able to read data from the device fast enough. If this is the case, then the trick is to determine why. To sustain a continuous acquisition, you basically have to be able to read/process data read at least as fast as the device is sampling. There are a few common things that we can look at if this is what you are trying to do. Please reply back and let me know if you are attempting a finite acquisition, or if you are performing a continuous acquisition. As I mentioned earlier, if you could post your VI, it may help to determine what is happening.
Looking forward to hearing back from you,
Dan
09-08-2005 04:09 PM
09-09-2005 04:55 PM
09-12-2005 09:42 AM
But when I tried to use DAQmx to create my acquistion program, it says "no device found",( while the traditional program can fidn the device), so I just don't know what to do next.
09-12-2005 11:11 AM
Is it possible that because PCI 6115 is a new Board, and the DAQmx does not recogonize it?
So I should download a newer version of DAQ mx which can rocognize my new PCI 6115 BOARD?
09-12-2005 11:20 AM
fenny,
NI-DAQmx 7.4 was the first versoin of DAQmx which supported then 6115. If you have an older version, then your 6115 will not be recognized. I would reccommend that you install version 7.5, as it is most up to date and had several fixes for that device.
Dan
