04-14-2011 05:50 AM
Hello.
We are a group of students who are looking for a way to use our blood pressure measurements in labview.
What we want to do is to have labview display the peak value when our curve tops the first time, then hold this value for some seconds.Then show the new peak value
and hold this a few seconds and so on.
Right now we can get it to show the peak value but it updates all the time.
We have tried different approaches but none of them seem to work.
we have attached our project as it is right now. maybe someone can help.
Thank you.
Solved! Go to Solution.
04-14-2011 05:55 AM
hello
it's possible to change your file in LabVIEW 2009
04-14-2011 06:04 AM
Should be labview 9.0 now
Thanks for replying so fast
04-14-2011 06:05 AM
Is this what you are looking for?
Nitzz
(Kudos are always Welcome)
04-14-2011 06:25 AM
Not exactly,
We would like the program to display the peak value over a period of 3 seconds continuously, by that we mean we would like one peak value for each 3 sec interval.
we hope you understand what we mean
and thank you for your help.
04-14-2011 09:08 AM
I think this is what you are looking to do. If you change the peak timeout on the front panel it will change how often the display updates.
04-14-2011 09:46 AM
After reading your post a little more closely and looking at the other suggestion on how to solve your problem I think this is what you want to solve your problem.
04-15-2011 01:13 AM
that worked out perfectly.
thank you very much 🙂
we will take a look at it now and then try to find the valleys aswell.
05-11-2011 07:03 AM
I sent you a message about this. If you have other questions you should use the board. I get notices that you have responded here I do not get an email when you private message me.
01-24-2012 12:00 PM
Can you please post the last VI in LV 2009?
