observe the frequency from voltage signal using MyRIO analogue pin
Hi all i am still student and i am doing a project to build simple NILM based power analyzer using MyRIO. I want to capture the characteristics like  frequency, phase angle from the voltage and current signal. Since the MyRIO gives integer values i need to generate waveform to use waveform measurement vi. and get those characteristics. I have use this method but still i dent get any values for the frequency or phase angle.
what would be the problem.
Thank you
(232 Views)
Accepted by topic author Gappiya
Hi gappiya,
please do some beginner tutorials before starting to code in LabVIEW: your image shows several misunderstandings typically done by beginners...
Right now you create waveforms containing exactly one sample: you cannot determine any frequencies or phases from single samples!
The myRIO gives no integer data as can be seen by the orange wire. Instead you get scalar samples...
(176 Views)
