multiple NI USB-6525
Hello, i intend to plug 3 NI USB-6525 into a PC to achieve 20 SSR switch.
how NI MAX will differentiate the 3 USB device?
can i make a fixed "alias" to a particular USB-6525 so that even if i plug it to a different USB, NI MAX still able to link this "alias" to the same particular physical USB-6525?
if not using alias, does the "VISA resource name" in NI MAX can be use as unique identifier? such that i plug 1 particular USB-6525 to a different USB port will resulting the same "VISA resource name"?
Thank you.
(1,049 Views)
Accepted by topic author jackson_thom
Hi jackson,
MAX will differ those 3 DAQ cards by their serial number.
And you can give them different alias names: the alias too is linked to the corresponding device by its serial number.
Additionally you can read the serial number using DAQmx properties so even your VI can differ those 3 DAQ devices independently from alias name…
using LV2016/2019/2021 on Win10/11+cRIO
(1,002 Views)
