is how can I calculate how many transitions are inside an array?
Let’s assume that we have an array of 582 elements. Some of them are above 4 and some of them are below 1,let’s also say that values who are above 4 are equal to True (1) and the values below 1 are equal to False (0). The question is how can I calculate how many transitions are inside the array from 1 to 0?How many peaks I have? Can please someone suggest a code solution for that?
Message 1 of 8
(2,779 Views)
OpenG toolkit has a function called "Boolean Trigger" that can help you.
here's how it works.
hope this helps
Epictetus
Antoine Chalons
Message 2 of 8
(2,764 Views)
It looks bit challenging I have tried an Example but am not sure how good it works.
Good Luck
Message 3 of 8
(2,762 Views)
P Anand no this not helped., iwant to calculate how many transitions i have from 1 to zero and zero to 1,that's i want to find.i am trying to downloan the toolkit the friend mention to see how it works.Any other solutions please?
Message 4 of 8
(2,750 Views)
The example I gave in my previous post works on an array of boolean, as I understand you have an array of numeric so you'll have to add some threshold value so it works.
What I suggest is that you try to implement it and if it doesn't work exactly as you wish, post it here and we'll help you to fix it.$
good luck
Epictetus
Antoine Chalons
Message 5 of 8
(2,743 Views)
If you only care about actual transitions and not the type of them, I'm a fan of the simple XOR.
GCentral
Message 6 of 8
(2,739 Views)
Accepted by topic author gtathatos
Yes I have tested the one before now I have tested it I guess this should work. Check it.
Message 7 of 8
(2,732 Views)
Quite simple.
Norbert
EDIT: Hehe, just seen that it is indeed very comparable to crossrulz' approach 😉
EDIT 2: Adding improved example
Norbert
Expert: Geometry
Message 8 of 8
(2,729 Views)
