Try to attched VI - I use it to test my serial instruments. Type the following into the "String to write" control (without the quotes): "\129\129\67\0\232\3\44\4"
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files,
you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
