09-09-2008 07:59 AM
I`m trying to fit a curve like a*exp(-b*x)+c to some data, by using the Curve Fit function in LabVIEW 8.0 (Mathematics -> Fitting-> Curve Fit). But, unlike other fitting routines, this one doesn`t accept arrays as inputs, so it converts them to Dynamic Data and every time a try to run the program I always end up with this error message:
An exception occurred within the external code called by a Call Library Function Node. This might have corrupted LabVIEW`s memory. Save any work to a new location and restart LabVIEW.
VI "test.vi" was stopped at node 0x0 of subVI "NI_AALPro.lvlib:Real SVD Decomposition.vi"
After this, I save the file to another folder and restart LabVIEW but the error still persists... I probed the Dynamic Data generated and it seems OK.... any ideas?
Thanks in advance,
Diogo
09-09-2008 11:39 AM - edited 09-09-2008 11:40 AM
Attached is a quick rewrite to get you started.
09-09-2008 05:10 PM
