how to programmatically change the width of a graph?
How can I programmatically change the width of a Waveform Graph or Waveform Chart? When I create an implicit property node for a graph or chart, it is read-only. Changing the plot bounds worked in earlier versions of LabVIEW, but not anymore.
(4,721 Views)
Accepted by bmihura
It works for me in LV2013 but I'm using the Plot Area : Size : Width property.
(4,697 Views)
NIquist,
You are right, it is "Plot Area", not "Plot Area Bounds" that works. My memory failed me. Thanks!
(4,686 Views)
I use Image Display in vision development. I can only get the property node of a Image Display. How can I get the property node of Plot Area?
(3,432 Views)
