02-23-2009 08:37 AM
sir
i want to tranfer an audio or image file through serial port so how can i do that?
02-23-2009 08:39 AM
03-03-2009 04:10 AM
hello sir.
I am Prabhu from chennai. i dowing new project in vision. it is "image transmission through serial port". but sum errors in this project. that is array(converted image) value is not convet in to image file. i attach this file please check this. and reply me my mail id: kgp.usic@gmail.com
03-03-2009 04:28 AM
Hi friends
I am Joseph from London.
I am trying to find the answer of your question so can you send some detail of
the above question.
Joseph
03-03-2009 07:06 AM
hello sir
thanks for your reply.
i doing new project in vision. it is "image transmission through serial port". but sum errors in this project.
that is first one image file(jpeg,bmp) is converted to array format .
and array value converted to spreadsheet string. this string value send through visa serial writh vi.
errors:
but visa serial receiver vi is not accept this string value.;
& array(converted image) value is not convet in to image file.
pleas explain the IMAQ array to image (convertion) . vi
03-03-2009 07:13 AM
Hi i want im...,
i can't open your vi, but it sounds for me like you can use the "Flatten to string" function.
Mike
