i have made a hamming encoder and decoder and i want to evaluate the whole performance of the system so i want to to flip a certain bit (representing the effect of noise ) so the the decoder detecte this error and correct it , i tried to use a subarray to select one bit then compare it to zero (which i couldnt do mismatch data type) , how can i fix this problem?
