help please
hi there
i am new for using labview
i have missing daq assistant from my software labview as show in the figure
how can i found this icon ?
help
(2,398 Views)
Accepted by topic author waleedabdurhman
Did you install DAQmx driver?
(2,394 Views)
No i just install the software
should i install it to run ?
(2,391 Views)
If you want to use DAQmx VIs, you need to install it. If you do not install it, you cannot use these VIs.
Here you can see the compatibility list: http://www.ni.com/product-documentation/53326/en/
So check what LabVIEW version you have, and install the latest DAQmx driver for it. Example: if you installed LabVIEW 2017, then install DAQmx 17.1
(2,376 Views)
