connection tcp labview problem with command.
Hello ,
I Have one qustion.
I have card relay with communication TCP .
my commands  is char .
simple
char(254)
char(108)
char (0)
I have array  [254,108,0]
my communication is good with out error. but I dont know problem .
why this command  not work ???
this command  on the relay in bank 0
ncd relay card.
Message 1 of 8
(2,460 Views)
@maklevit wrote:
Hello ,
I Have one qustion.
simple
char(254)
char(108)
char (0)
ncd relay card.
this is from the NCD site: http://assets.controlanything.com/Software/labview/RelayDriver.vi maybe you can adapt this to what you need?  It looks very similar...
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(2,451 Views)
I suspect you need a termination character...
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(2,450 Views)
Hi, billko,
where did you find the command set [254 108 0] to switch relays? I cannot find them. If you could provide the source, it will be greatly appreciated.
Message 4 of 8
(2,385 Views)
@MengHuiHanTang wrote:
Hi, billko,
Sorry, I didn't get them from anywhere.  I wasn't the original poster.  I only provided a link to the communications VI.
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(2,382 Views)
I know this post was from last year, but did you resolve the issue? I am having the same issue. Trying to switch relays from LabVIEW, but don't know what command set to send to the WiFly by TCPIP.
Message 6 of 8
(2,377 Views)
If you were speaking to me, I wasn't the one with the problem.  I don't know if the original poster solved the issue or not.  There must be some documentation floating around on the internet somewhere - I hope!
Sorry i can't help you.
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(2,367 Views)
http://zone.ni.com/reference/en-XX/help/371361J-01/lvcomm/tcp_vi_descriptions/
www.rovingnetworks.com/resources/.../93/wifly_user_manual
Maybe those two links will put you in the right direction.
Tim
TimC
Applications Engineer
Message 8 of 8
(2,333 Views)
