I have a program called say PROG.VI inside a directory with other vi units. Running the vi is fine. When I go through the build proces using this vi all is well.
When I build using the LVproj route it builds ok but does not pick up some sub.vi units
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
