beep sound
i want a beep sound to be generated whenever a peak is found in the analog graph. how to do it?
(4,167 Views)
There is a "beep.vi" on the Graphics and Sound palette.
Call it when you detect the peak.
I usually put the beep code in a subvi that is fed by a queue.
Your implementation will depend on how you want it to work.
Is it a one time beep or does it beep as long as the value is above a limit?
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
(4,153 Views)
Are you searching peak values in a periodic waveform or a random waveform?
Actor Framework rocks!
Emre TUZUNER
(4,152 Views)
its just a one time beep. i am not able to get how to call it when peak is found. Could u please attach an example
(4,148 Views)
Here you can find a VI. VI creates a beep sound every peak of a sine waveform.
Emre TUZUNER
(4,133 Views)
your labview version is higher than mine so i cannot open the vi. plz attach the snapshot
(4,130 Views)
Sorry for that. Here is the sc. You can adjust the duration and frequency of the tone. Details can be found in context help.
Emre TUZUNER
(4,125 Views)
