background color xls file
hi,
short question,
i write in one cells in a table another background, for example blue. some while-rounds later, i wanna save this color information in a xls-file.
how can i do this??
thanks for the support
greeting christian
(2,193 Views)
Look at the example file called Write Table to XL. It shows how to open Excel using ActiveX and write a table to a new workbook. Inside the inner for loop, you can create a new vi that sets the Interior.ColorIndex properties of the cell in the same way that the Value is set. Just use two property nodes, the first set to Range->Interior and cascade that output into the reference of the second property node and set it to Interior->ColorIndex.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.0, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,182 Views)
