add vi from earler version to LabVIEW 8.0 Project
I have a large number of vi's from 7.1 and I need to add them to 8.0 projects. What is the best way to add them rather than create new vi's?
(2,333 Views)
I would recommend copying the files you want to add to your project to the directory where you have your other 8.0 VIs for that project.  Then you can open those VIs in 8.0, save them in 8.0, and add them to your project.  This way you'll still have your 7.1 copies in case you need them later.
Best Regards,
JLS
Best,
JLS
Sixclear
(2,323 Views)
