Wiring data through multiple frames of a Flat Sequence
I'm wondering which way to wire data through multiple frames of a Flat Sequence is better. The top option is to just wire frame after frame, the bottom one is to 'exit' the sequence and reenter it later. The code shown is trivially simple, but imagine there are many variables being worked on in that sequence frame by frame, but some of the variables are only used closer to the beginning and then closer to the end of the sequence, as shown.
Message 1 of 24
(2,001 Views)
Hi Vitek,
The best option is to not use a sequence frame at all…
Message 2 of 24
(1,996 Views)
Most of us here will agree with GerdW.  Whatever you were planning to put in those frames is FAR better off in a subVI and wiring their error terminals  to sequence them.  Or, build a proper state machine so you have even more control.
It would be best if you tell us what you're trying to achieve so we can suggest the best architecture to implement.
Message 3 of 24
(1,979 Views)
Haha I kinda expected the "Never use a sequence dude" answer 🙂 I know it's suboptimal, honestly I'm mostly using it to visually organize the code, not to achieve a specific functionality.
Answering your question, I'm using it in a subvi that executes one step of 4th order Runge Kutta on a set of 3 ODE's, on arrays of values. See the snippet below:
I realize that from dataflow standpoint, I probably don't need the Flat Sequence at all - my question is more conceptual than practical.
Message 4 of 24
(1,967 Views)
If it is for "organizing code" then why not use
Structures -> Decorations -> Flat Frame
Certified LabVIEW Developer (CLD)
Message 5 of 24
(1,963 Views)
Well, the sequence structure forces LabVIEW to execute in a sub-optimal fashion, so there's a reason behind the advice.  Use the Flat Frame decoration to separate your code visually.
Bill
CLD
(Mid-Level minion.)
Message 6 of 24
(1,960 Views)
Dang, you beat me to it.
Bill
CLD
(Mid-Level minion.)
Message 7 of 24
(1,959 Views)
Frozen, that would certainly work. Does using Sequence automatically slow down the code or in any other way "harm" the performance? In my code there is really nothing that could cause variable race or ambiguity in the output values.
Message 8 of 24
(1,958 Views)
Forcing your code to execute using a sequence structure is like forcing your car to fire its spark plugs at your discretion.  Best to leave the engine to do things the way it needs to - for both cases.
Bill
CLD
(Mid-Level minion.)
Message 9 of 24
(1,952 Views)
Bill, that makes sense. I guess my original question will remain unanswered, since Sequences are a taboo topic, but I appreciate your responses.
Vitek
Message 10 of 24
(1,946 Views)
