Our online shopping is experiencing intermittent service disruptions.
Support teams are actively working on the resolution.
03-15-2024 05:35 PM - edited 03-15-2024 05:38 PM
@cgiustini wrote:
Yes, exactly I want to change the FPGA. That is still possible on the latest VST hardware/software right? Or do you know if that capability was removed?
I don't have hardware just yet so I cannot test whether or not RFSA and RFSG software front panels or examples work. But I do know that at least the soft front panels are there, which indicates that RFSA and RFSG software has been correctly installed.
Yes, you can still use a custom bitfile. I believe you need NI RIO drivers. NI RIO will be encluded with the hardware.
03-16-2024 06:46 AM
I think RIO driver is the term used when LV FPGA first came out when there were less product lines. As above, the term is still used. These days I recommend being more product line specific (e.g., FlexRIO, R Series, cRIO).
To load a custom bitfile into any of the 1st and 2nd gen VSTs, see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g2pKSAQ&l=en-US. You just need the RFSA and RFSG drivers.
VST3 (5842) does not currently show anything in the documents I checked.
03-16-2024 06:51 AM - edited 03-16-2024 06:59 AM
@JÞB wrote:
I would be looking at RFmx. RFmx (Radio Frequency Measurement eXperience) builds on top of RGSA / RFSG similar to how DAQmx replaced Traditional DAQ. I would certainly have expected that pre-RFmx IDL support would be obsoleted by now.
Check licensing for this. RFmx is not free, see https://www.ni.com/en/shop/wireless-design-test/application-software-for-wireless-design-test-catego...
RFmx will be a replacement to RFSG and RFSA when there is a part that is free (as part of hardware purchase).
03-16-2024 06:55 AM
I recommend getting an official answer directly from NI.
03-16-2024 02:11 PM
Hi again
Found the IDL download location for the now very old versions, and NI's statement about that :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g2pUSAQ&l=da-DK
Quote : "For the majority of use cases, NI recommends using the pre-compiled reference FPGA image provided with NI-RFSA, NI-RFSG, and NI-RFmx."
There are only downloads for these LV 2013 to 2015 compatible IDL versions :
Here :
Regards
