Our online shopping is experiencing intermittent service disruptions.
Support teams are actively working on the resolution.
08-28-2012 07:55 AM
Hello friends,
I want to resize the FP, I am attaching screen shot with minimum and maximum FP look of other VI. in this Vi when I maximize the screen .Control remain same in shape ....
08-28-2012 11:14 PM
As I mentioned in my earlier post, did you check the VI Properties?
Your vi works as you want it to, if you uncheck the settings in Windiow Size of the VI Properties.
08-29-2012 04:30 AM
Hello
Yes, I tried all possible option, still when it maximize.. Dial controls are unshaped ....
08-29-2012 05:15 AM
Ok
I am not sure why this is so. However, i can suggest a work around for you. it works
This is not the best method to do it, but as i said, a work around.
you select the controls on the tab page (all of them above the waveform graph), as shown in the picture attached.
Group the controls and lock them as shown in picture. this should work
08-30-2012 01:37 AM
Thank you...
