Unable to send DIO siganl using LabVIEW FPGA Module and MyRIO
Everything works when no FPGA is used. So the harware and circuit are working.
However when targeting FPGA module on MyRIO, the data acquisition and processing works and the signal to the motors is "sent" (visible when Hightlight Execution is enabled).  But there is no voltage on the DIO ports used. The FPGA projects includes VHDL code.
Do you know what might cause this problem?
(2,589 Views)
Accepted by topic author aan928
You have to control the DIO through the FPGA.
GCentral
(2,583 Views)
