03-07-2011 10:02 PM
I'm installing LabView 2009 on Windows 7 on my Hp and when I run the setup after I unzip it, it come up with an error and says "Unknown Error". How do I get around it to install the program as soon as possible.
03-07-2011 10:59 PM
You said unzip it. Where did you get it from? A download? If so, perhaps it is a corrupted download. Try downloading again.
03-08-2011 02:36 PM
I have tried to install it straight from the disk and also tried to download the version online to input my licence key. Niether work.
03-08-2011 02:37 PM
03-08-2011 04:05 PM
Owen-
You get the same error when you do a fresh install from the disc? If so, is it a 32-bit version of LV 2009? If it is a 64-bit version of LV, are you installing it on a 64-bit version of Windows? Can you post a screenshot of your error?
Sean
03-09-2011 09:23 PM
I get the same error from both the disk and the download. Let me post a screenshot of the error
03-09-2011 09:29 PM
Intel Core 2 Duo CPU @ 2.53GHz
4GB Memory
32-bit OS
HP 6530b Windows 7
03-09-2011 09:31 PM
This is a screenshot of the error...
03-09-2011 10:23 PM
What does it say if you click on the Details button?
Do you have admin rights to be able to install software on this PC?
03-09-2011 11:10 PM - edited 03-09-2011 11:11 PM
Have you tried copying the DVD's contents to the hard drive and running the installtion from there? Have you tried to make sure your anti-virus software is off while you are doing this? Have you tried booting the machine so that no other third-party services are running?
