Unable to Control an cRIO real Time Analog out in 1kHz
Hi, I'm wondering why I can not control an AO faster than 100Hz in cRIO Real time?
Hardware: cRIO-9067, Module NI9263 (100 kS / s / ch)
See pictures.
I would need to be able to control AO at 1kHz without the FPGA.
Does anyone have an idea.
20ms
10ms
9ms
7ms
6ms
5ms
(506 Views)
Hi Niklas,
Because you are using the ScanEngine - with all its limitations!
Use the FPGA to get precise timings, especially at 1kHz and higher…
using LV2016/2019/2021 on Win10/11+cRIO
(503 Views)
Thanks for your reply.
I suspected that.
The problem is that it is sporadic when we need to change the AO value. This information comes via CAN module.
Will we need to implement everything in the FPGA for this, including CAN?
(495 Views)
Hi Niklas,
I would prefer to implement it directly in the FPGA…
(483 Views)
Thanks for your answers.
(478 Views)
