Trouble communicating with SR865A LabVIEW driver using RS 232 serial port
Using NI MAX I ensured that it is communicating using RS 232 (using command *IDN?\n  no error is found), but when I run the lab view program in block code at VISA open Error -1073807346 is showing any lab view support will be appreciated.Error -1073807346.JPG
(398 Views)
Well that error usually means something already has the VISA resource open. (Another program, The VISA Test Panel in NI-Max, etc)
Also since you seem new to LabVIEW serial communications, I suggest you watch this video: VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(394 Views)
Typically for Stanford Research you had to specify the communication bus with the command OUTX, if I remember correctly, OUTX1 was GPIB, OUTX0 was serial, but look that up in the manual. This should be done at the beginning of the program.
(369 Views)
