Trigger Event through file path control
Hey guys,
I'm using a vi with a file path control and an event structure. I want an event to be triggered when a new file is loaded. I put filepathin: value Change into the Event structure, but this does not work. How could I do it?
(1,806 Views)
Hi volfi,
Where and how is the file "loaded"?
How is the value change event of the filepath control related to your "new file is loaded"?
using LV2016/2019/2021 on Win10/11+cRIO
(1,803 Views)
the file is loaded through a file path control in the front panel. The file contains some data which I want to be displayed as soon as I select a new file.
(1,794 Views)
Accepted by topic author volfi
Hi volfi,
when you select a (new) file with your filepath control you should get a value change event for it.
In the event you should load your data.
When you handle things different in your VI then you should attach this VI - that's the way to get better answers here!
(1,784 Views)
