09-26-2016 05:45 AM
Another block on my project is unknown. Does anyone knows how to find this block? Thanks.
09-26-2016 05:50 AM
This is a property node for a control (implicit binding).
Maybe you should work through the basic LV tutorials. I am pretty sure that these items show up there....
Norbert
09-26-2016
05:52 AM
- last edited on
05-21-2024
07:15 PM
by
Content Cleaner
-That is property node for the image indicator.
-If you have started just learning LabVIEW please check these links:
Start with below links to learn about LabVIEW programming
LabVIEW Graphical Programming Course
09-26-2016 08:55 AM - edited 09-26-2016 08:56 AM
In addition to the advice mentioned above, if you right-click on a node, the resulting menu usually has a "Help" selection - in the case of property nodes, you will usually get TWO "Help" selections - one for generic property help and one for help with the specific property chosen.
