Is it possible to automatically generate a State Diagram from an existing LabVIEW State Machine using the State Diagram Toolkit, or is it necessary to manually generate it?
I have not seen the state diagram toolkit until you mentioned it. But, generally you want to plan out your software before you code it up, not the other way around.
