Sorensen power supply driver
I am looking for a Labview driver to remote/communicate with Sorensen XPF60-20DP power supply.
There is no XPF series driver available on the NI instrument driver list.
Please advise if possible that one of the other series is similar enough that the same drivers will work for XPF60-20DP.
I appreciate your help. Thank.
(3,162 Views)
Accepted by topic author CTNG
Hi CTNG,
IMHO opinion the manual contains all the information you need to create your own set of driver VIs…
@CTNG wrote:Please advise if possible that one of the other series is similar enough that the same drivers will work for XPF60-20DP.
Most often devices of the same model line use nearly the same command set. It should be easy to adapt drivers for similar models of the same brand.
(3,100 Views)
If there is no driver available then you will have to write your own.
The manual has all of the commands and interface descriptions you should need starting at page 31.
Honestly all "LabVIEW drivers" are noting special and are usually just a set if VI's that someone else has made from all the commands in the manual.
=== Engineer Ambiguously ===
(3,057 Views)
