01-21-2018 11:16 PM
Is any formula to solve the below equation in LabVIEW
3*x^1/2+2*x+7*x^3/2+2*x^2+5*x^5/2=2
Thanks in advance
01-21-2018 11:37 PM
If you have a formula, it does not depend on the programming language. Nothing to do with LabVIEW.
Is x guaranteed to be positive?
If you don't have a formula, you could e.g. use e.g. Newton-Raphson with a few iterations starting with a reasonable guess. A nice programming exercise. 😄
01-22-2018 10:15 AM
Have you tried using the formula node?
01-22-2018 11:38 AM
It is "=2", not "+2" and he wants to solve for x.
01-22-2018 12:05 PM
Yeah I know, I wasn't sure if I was being too simple but assumed that he would know to rewrite the equation so that 2( as a variable) is the input and X is the output.
X= 0.222647?
01-23-2018 03:18 AM
Thanks to everyone for your valuable inputs.
Atlast i solved the equation by doing some modifications in the vi which i downloaded from forum and am attaching the same vi here
01-23-2018 05:50 PM
Brabin777 wrote:Atlast i solved the equation by doing some modifications in the vi which i downloaded from forum and am attaching the same vi here
When quoting somethings from the forum, please include a link! Do you have a link?
Why is the VI so messy?
01-23-2018 06:13 PM - edited 01-23-2018 06:16 PM
Don't forget that there will be quite a few more roots, some complex. In this case, there is one real root and you can find it as follows using this VI. (Of course you need to make certain assumptions about x). In the more general case, use this VI to sort out the real roots.
01-23-2018 11:16 PM
As mentioned earlier here is the link where i got vi to solve the equation https://forums.ni.com/t5/LabVIEW/Solving-Math-Expression-using-Labview/td-p/2113376
11-05-2018 07:15 AM
The „Solve Linear Equations VI“ works differently in PC and in Realtime. When I run the attached VI in the PC (without compilation) it gives TRUE. The same VI when I run in Real time Project (cRIO – with compilation) it gives FALSE.
I have gone through the VIs and I found different function for different target (Default & RT Target). Why its different for various target? The result without compilation (Default) is correct value. How I can use that?
Whether the DLL format is not supported by Realtime?
Thanks & Regards,
Shree
