I am recording 128 anologue channels and would like to have a spreadsheet (name of spreadsheet file given by looking in the contents of another file i.e file.txt contains 1234 therefore spreadsheet file is called 1234.txt) which has the channel name (AI0 = name given by virtual channel already defined i.e css_L1_01) at the top of the spreadsheet and a timestamp for each sample (as below)
I am doing this in a while loop so I could use the increment counter a nd times it by the time per loop (200ms) but I am having difficulty geting a proper output.
To summarise I would like to be able to get the virtual channel names and put them on top of the data aquired and I would like it timestamped and the spreadshhet given a name which is aquired by looking at the contents of a file.
I have been trying to do this for days with no luck!! Any help would be most appreciated
Hi Dave Try this, I use a csv format, but you can modify it for your requirements. The file containing the filename assumes there is no file extension.
