01-23-2014 10:38 AM
I am wondering if I could get some help trying to capture a waveform measurement in LabView using an analog input. I attached a picture of the waveform I'm trying to capture and the values I'm trying to read. Would this type of measurement be possible in LabView
01-23-2014 10:58 AM
What rate is the waveform oscillating? What rate do you plan to sample at?
As far as measuring those value, it is a matter of finding the right ranges to sample at. What I have done for something somewhat simlar was to make a moving RMS on the entire waveform. This should result in something like a square wave. From there, you can look for the edges. That will give you the ranges to do your amplitude calculations on the original waveform.
01-23-2014 11:16 AM
The main frequency is approx. 20.5kHz and that frequency is modulated at approx. 17Hz. I am currently sampling at 200k samples/sec
01-23-2014 11:54 AM
Alright. A standard DAQ card should be able to do that. If you aren't sure how to use a DAQ card and DAQmx, look in the LabVIEW examples. Then try the analysis, which I described above.
