05-27-2022 09:51 AM
Is there an easy option to plot a graph with the value distribution in percent. I want to get something similar to in the picture. If I try to make myself, it will be big and chaos. Thanks
05-27-2022 09:56 AM - edited 05-27-2022 10:00 AM
You can change the format of the markers accordingly, e.g. "%.0f%%" (use the advanced formatting option)
05-27-2022 09:59 AM
05-27-2022 02:59 PM
These are the rms of weighted values. I have to show the percentage of each value from the list. I was thinking maybe there is a built-in function which is like histogram, but more specific to my need, then I don't have to program it.
05-27-2022 03:27 PM
Well, your problem description was not clear at all, because I took it as a cosmetic problem. To calculate a normalized integral, that would be an easy data operation. Start by attaching some simple data.
05-27-2022 04:06 PM
05-28-2022 04:47 AM
That's exactly what I need, but the code isn't quite clear. Could you please elaborate or upload an example if don't mind.
05-28-2022 06:23 AM
Well, there is a built in function like that. Surprisingly it is titled Histogram.vi
Altenbachs code is simply faster.
05-28-2022 06:28 AM
Altenbachs code is simply an extremely efficient way to scale and sum the counts of the bin outputs after passing the raw values through a histogram.
05-28-2022 08:35 AM - edited 05-28-2022 09:31 AM
The quality of my answer cannot be significantly better than the quality of the question (well, sometime I guess right and it is!).
Apparently, you have several analysis steps:
Initially, I thought you needed help with #4. Later I added a solution for 2&3, still assuming that you already have the histogram data. Now you are telling me that you also need help with #1. Who could have guessed!!!
I have asked you to attach some typical data, which you did not do, but would have cleared things up. I am not clairvoyant! Once you decide to attach some data, I will attach the full solution. Until then, it is a waste of my time to keep guessing what your problem really is.
Yes, LabVIEW has built-in functions to calculate histograms, but I would recommend an even simpler solution. What is the data range (0 to 0.1??)? How many bins do you want (100?)? Do you also need a bin for values that are outside the range? No matter what, the code is trivial and probably fits on a postage stamp. 😄
