Phase angle measurment
I need to measure the phase angle of a waveform.Is there any method to find the phase
(2,628 Views)
hi,
you can use AmplitudePhaseSpectrum method to compute the phase angle.
vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(2,591 Views)
Thanks for ur reply.
can u pls send sample code for this in LV8.5.I herewith attached the sample waveform for which i need to calculate the phase.
(2,580 Views)
sorry here the attached sample waveform
(2,578 Views)
have a look at the following VI. Maybe this might help. The phase is the starting phase.
regards,
Vaibhav
...//____//......
..//____//......
.//____//......
(2,548 Views)
