PXIe-1092 and cards
lately I have some problems with my PXIe-1092 when I observe the NI MAX. I notice the absence of the chassis while all the boards are present even if they are not reachable as you can see in the picture:
I have already tried to follow the steps in this help https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fzLMSAY&l=it-IT but nothing has changed. So is there anyone who has overcomed this issue? Also because tur on and turn off the PXI and my PC until everything is fine seems quite awful to me.
Thank you for the help!
Best Regards,
Zuc
(287 Views)
What is the model of the controller installed in the Slot 1?
If you are using an MXI controller, you should check out the steps in MXI-Express Compatibility and Connectivity Troubleshooting Guide
Control Lead | Intelline Inc
(258 Views)
Hi ZYOng,
If you mean the card with the USB-C connection it is the NI PXIe-8301.
The only way that i have found to solve my issue was to repair all the related packages installed on the PC. After the reboot everything is ok.
I don't know if those problems are coaused by the turning off of the PC and the PXI, maybe there is a particular sequence in the operations that i have to follow.
Thank you for the help i will read your link.
Zuc
(250 Views)
