Our online shopping is experiencing intermittent service disruptions.
Support teams are actively working on the resolution.
01-21-2019 05:30 AM
Hello !
after i changed my PC from windows 7 to 10, all project work same except alarms not showing and not logging.
please tell me why is this problem
asif iqbal
Solved! Go to Solution.
01-21-2019 06:34 AM
"After I put gas in my car, it stopped running. Can you tell me what the problem is with it?"
01-21-2019 11:32 AM
What RavensFan is saying ...
We need a lot more information before we can help you out at all. What project? What do you mean by "Alarms". What do you mean when you say they aren't working? What have you tried so far to troubleshoot?
01-22-2019 07:22 AM
And can you attach a simple example (or even the entire "not-working" Project) so we can see this anomalous behavior and try to understand what you mean? Having actual code to examine and try out is really helpful for understanding the nature of the problem and devising (where possible) a "fix".
01-22-2019 10:14 AM
Can you give a more detailed explanation of the problem?
01-22-2019 10:39 AM
Actually that's a pretty straightforward problem with relatively few branches on the troubleshooting tree compared to the issue presented to us by the OP. 😄
01-22-2019 01:18 PM
Usually putting gas in the car helps it start running again far more often than causing it to stop running!
01-22-2019 02:04 PM
Really? 😄
01-22-2019 02:09 PM
Twice, I had run out of gas and putting gas in allowed it to start again. (Bad fuel gauge I hadn't gotten around to replacing until the second one.)
I've never had a car that was running, stop because I put gas into it. Luckily I haven't been to a station that had screwed up their tanks.
But really, I wasn't intending to get into debates how cars stop running. Just trying to put in a basic comment to reflect how stupid a question is that provides zero information. I would have thought the OP would know how to ask a better question after 134 posts on this forum.
01-22-2019 02:15 PM - edited 01-22-2019 02:17 PM
So you had a perfectly running application under windows 7, then you upgraded that same PC to windows 10 and things no longer work as before. Is this correct?
What are "alarms"? Are these just front panel objects or some hardware connected to DO, AO, etc. (buzzer, siren, fog horn, etc.)
Possible reasons:
