Need help with data rate of NI 9189
Hello everyone ,I am using NI 9189 chasis, along with 9205,9263,9472.
During aquring the data over the ethernet i am not getting more than 10Hz.  For my applicaton I need at least 100 Hz data from the chasis with real time.
when I have tried to increse the frequency of the system. I am getting that data with a delay of 2-3 seconds.
Help me to solve this.
I am working on a close loop control system, where I need a real time data in high frequency.
Thanks in advance
(699 Views)
Unfortunately, Ethernet communication has milliseconds of latency. (Instrument Bus Performance – Making Sense of Competing Bus Technologies for Instrument Control)
When using cDAQ-9189, the data are sent to your host PC to process.
If you want to do closed-loop control, you should use cDAQ-913x or cRIO with standalone controller.
Control Lead | Intelline Inc
(657 Views)
Can you share the code ? From your description, it's difficult to make any assessment. Please share for LV 2020
(653 Views)
Here is the code
(576 Views)
We see no attachments.
(563 Views)
sorry, Here it is
(538 Views)
