Hi everyone, I'm having a situation installing XNET toolkit on a machine, I installed Labview 2012 SP1 in two machines that will use this toolkit, then installed XNET 15.5, both machines are windows 7 64 bits, in one machine the toolkit was installed correctly, I can see the function palette in Measurement I/O ---> XNET, but in the second machine, after installing, the function palette is not showing, I uninstall everything and start from scratch and still not showing, I installed XNET 20.5 and still not showing, NI MAX shows that the toolkit is installed, the folder and DLL is in the same path as the other machine, I tried install it manually but it throws an error that says that the toolkit is already installed, does anybody knows what can be happening or what are we doing wrong?
