The display settings for NI MAX are dependent on the Windows settings, which impact the behavior at high resolution. To fix this issue disable display scaling using the following steps.
- Locate your NI MAX shortcut in your Desktop or through Start >> Right-click NI MAX >> More >> Open file location.
- Right-click NI MAX and select Properties.
- Navigate to the Compatibility tab and select click Change high DPI settings to open a new sub-window.
- Check to Override high DPI scaling behavior. and make sure that the Scaling performed by is selected as: Application.
- Click Apply. Close the window and open NI MAX again. The font should be a regular size.
The above works if you are using just one monitor. However, if you are using two monitors, I recommend you to select System/System(Enhanced) instead of Application in the list options of Scaling performed by.
Attached image to exemplify.
I hope this information is useful to you.
