12-22-2021 07:33 AM - edited 12-22-2021 07:33 AM
My NI Max font is way too small. I have google fixes but unable to get it how I want.
Notice the column on the left is pretty small (I can live with this but would be better if bigger). Also, The create simulation box is way too small. I have not found a way to change the sizing of this. Any help would be appreciative.
Thank you
01-11-2022 09:59 PM
Have you tried changing the screen resolution from windows?
Also, if you are using windows 10, I would suggest checking the Scale and layout setting. In the past I have got some errors with NI software when changing this paramter.
I hope this helps.
01-14-2022 05:41 PM
The display settings for NI MAX are dependent on the Windows settings, which impact the behavior at high resolution. To fix this issue disable display scaling using the following steps.
The above works if you are using just one monitor. However, if you are using two monitors, I recommend you to select System/System(Enhanced) instead of Application in the list options of Scaling performed by.
Attached image to exemplify.
I hope this information is useful to you.
