Missing "Find Network NI-DAQmx devices" in NI Max
Hi team ,
Found weird issue in NI Max , not able to "find the Network NI  DAQ devices and Simulated devices option too . Repaired the NI DAQ option  from NI package manager .
Installed version -  NI LabVIEW 2021 SP1 version (32 bit ) .
Host OS - Windows 11 pro (64 bit )
Surfed few posts related and tried the below solutions too :
  1. ‘Create New…’ Button Missing When Adding a Simulated Device in NI Measurement & Automation Explorer ... --> I verified this and even upgraded the version to 21.8 from 21.3 (NI DAQ mx Runtime with  config support ) and confirmed the presence of  NI Max ADE support , NI DAQ mx Max config , NI DAQ mx Device driver too.
  2. Minimum Windows Services Needed to Run NI MAX - NI -  Gone thru this and Restarted every services mentioned in this post .
  3. I have done the Reset configuration data  under tools in NI Max too .
But still issue didnt able to resolve . Attached the S/w package below for reference. Guide me on this !!
(428 Views)
The first supported DAQmx version in Win11 is 2022 Q3. Try upgrading your software version.
Reference: NI Product Compatibility for Microsoft Windows 11
https://tmesystems.net/
(389 Views)
Hi zyong ,
Due to license issues , Windows 10 machine swapped now  . (Installed LabVIEW version : 2021 Sp1)
9189 Chassis was successfully  detected in new windows 10 machine .
Unreserved from the old machine too . Static ip was set , But modules was missing now !
Cant able to add the modules.
attached the error screenshot for reference .
(362 Views)
Error -201251 When I Try to Add a Device in NI MAX
(347 Views)
