I'm currently looking to drive a Metex Digital Multimeter in Labview and was wondering if anyone knew where I might find a driver. The multimeter that I have is an M-4650 CR.
serial port settings: 1200 bauds, 7 data bits, no parity, 2 stop bits Clear RTS and set DTR lines
It supports only one command "D\r" and send back a string with its actual readings.
Jean-Pierre Drolet
"Spencer Nelson" a écrit dans le message news: 3a706e3c@newsgroups.ni.com... > > I'm currently looking to drive a Metex Digital Multimeter in Labview and was > wondering if anyone knew where I might find a driver. The multimeter that > I have is an M-4650 CR. > > Thanks, > > Spencer Nelson
Jean-Pierre: How did you know how to set the 2 serial port signals? I used your info and got some simple LabVIEW code to read the string sent from my 4650 DMM. Now I'll create a driver for it and a practical app or two.
Spencer: Did you ever find or write a driver for it? I'll send you what I come up with if you want. Let me know if you have any ideas for what you might want it to do.
