LabVIEW bug or just a poor error message (1082) ?
Hi folks,
I tried to do something yesterday in LabVIEW 2022 (Q3) that I wasn't sure would work but thought I'd give it a go . . . I have an Enum holding a list of RAL colours and in hindsight realised there will be a need to add to this list after my code is built.  So I started working on a little sub-vi to do just that and got an error when I tried to run it . . .
my enum is a type def, not a strict type def . . .
I'm assuming that this is a bad error message and what it really means is "don't be an idiot, you can't edit an enum at run time"
Test code to reproduce error . .  .
enum is attached.
(1,412 Views)
Unrelated to the question, but a small warning that LV2023Q1 crashes when the snippet is dropped on the BD (for me). LV2022Q3 works fine. (same crash for other snippets)
Certified LabVIEW Architect
(1,402 Views)
Accepted by SimonGn
Hi Simon,
Yes, it's a bad error message and it really means the quoted senstence… 😄
(1,394 Views)
