LabVIEW Model Interface Toolkit compatibility
I have a compatibility question about LV + LV RT with LabVIEW Model Interface Toolkit, I would like to know if I can get the solution without installing a complete labview version...
If I am using Labview 2021 + Real Time 2021 32bits, is it possible to use LabVIEW Model Interface Toolkit with this Labview configuration?
I understand that version LabVIEW 2020 Model Interface Toolkit is not compatible with LV 2021 32bits, and I should downgrade to LV 2020 32bits
https://www.ni.com/pdf/manuals/375381e.html
neither version LabVIEW 2021 Model Interface Toolkit is compatible with 32 bits, and I should upgrade to LV 2021 64 bits.
https://www.ni.com/pdf/manuals/375381f.html
any thoughts on this? Thanks!
Message 1 of 1
(605 Views)
