From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
LabVIEW 8 development environment is unbearably slow
The LabVIEW 8 development environmnet is unbearably slow.  When working with a new, blank VI I do not notice any problems.  However, as I start to work on my larger VIs, especially my top level VI with ~1000 sub-VIs, then there is a significant time delay between most operations.  For example, everytime I delete a wire, LabVIEW "hangs" (more like thinks with its hourglass) for  3-5 seconds.  There is also a 3 to 5 second delay everytime I insert anything or move anything on the block diagram.  I am positive that my hardware is adequate (P4 3.2GH w/ HT, 1.5 GB RAM) becase there was no noticeable problems in LabVIEW 7.  Does anyone know how to speed this up?  Its gotten to the point where its so time consuming (just waiting for LabVIEW to refreash every time I do anything) that it is almost counterproductive to develop at all.  Yesterday it took me almost 3 hours to copy 30 controls, rename them, and insert them into case structures.  Any help would be greatly appreciated!!
Message 1 of 15
(4,097 Views)
Wow, I just received my LV8 upgrade and I regularly work with VIs containing 600+ subVIs.  Is anyone else having this experience???
Message 2 of 15
(4,086 Views)
I've notified our R&D department of this issue. Thanks for brining it up!
Best Regards
Message 3 of 15
(4,049 Views)
Do you have Tab controls on the front panel by chance?
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 4 of 15
(4,043 Views)
Yes I do have tab controls on the front panel.  Is there a known issue with this?  If so, is there a viable workarround (short of just not using them?)
Message 5 of 15
(4,029 Views)
There is an issue when using charts on tabs. I've had this problem, but didn't really see any problem on the block diagram. I just had the problems listed in the linked KB article. The article only lists 7.1.1, but the problem is still there in 8.0 and 8.0.1.
I'm just wondering if this is an extension of that problem. I suppose the applicaiton is too large to remove the tabs to see if that helps.
Ed
Message Edited by Ed Dickens on 05-05-2006 08:00 AM
Message 6 of 15
(3,999 Views)
It was an interesting article but not exactly relevant.  The KB article specified that the problem was in setting properties for the chart, and that it was sped up when the chart was moved from the tab.  I am experienceing absolute sluggishness with absolutely everything, not just charts on tabs.  But thank you very mush for the article.
Message 7 of 15
(3,975 Views)
I realize that it's not exactly what you are seeing, but my main reason for bringing it up was to make the AE looking into it aware of the existing problem so they can  try and see if they are related.
Ed
Message 8 of 15
(3,961 Views)
Forum,
We very much appreciate what you're going through and would like to look into it further. Would you be willing to set up a service request at support@ni.com and email in your application? We may have to set up an FTP transfer but we are certainly interested in helping out. Post to let us know what you think. Thanks!
Chris C
Applications Engineering
Message 9 of 15
(3,939 Views)
Hi everyone,
I'm having the same problems as described above. There is a freeze (hourglass) of about 9 seconds each time I do anything.
Was anything usefull found on how to fix this problem?
thanks in advance.
Daniel
Message 10 of 15
(3,772 Views)
