LV7 application build without diagrams
When I strip out diagrams and then do an app build in LV7 I get the following error:-
Error 1073 occurred at C:\lv7 error\lv7 without diagrams\internal.llb\hello world.vi
If I build the application with diagrams then no problems.
Examples attached....
Message 1 of 8
(2,738 Views)
When you built an application, the diagram will be removed during the built process. You probably should not remove it before that.
Message 2 of 8
(2,731 Views)
Thanks for the reply.
I actually need to build the application with some diagrams removed. I have been supplied libraries of subvi's with the diagrams removed.
It works fine in LV6.1. It seems that there has been a step backwards in LV7.
Message 3 of 8
(2,727 Views)
I have just tried the same thing with LV7.1 on a friends computer.
Works fine if I check "disconnect type definitions and unused polymorphic VI instances" in the application settings tab of the Application Builder dialog. This option not available on LV7.
Does that mean I have to pay to upgrade to 7.1 just to go back to 6.1 functionality?
Message 4 of 8
(2,723 Views)
One way around it if at least your toplevel VI has a diagram: Specify "Small target file with external file for subVIs" as built option.
After the built, you can substitute your own llb with the diagram-less VIs as data.llb. You might have to make a few dummy VIs with the same name for the built so they are called correctly. Seems to work, but sounds painful.
Maybe there is a better solution somewhere. I'm curious.
Message 5 of 8
(2,721 Views)
Hello mr_e_cat,
I found some information on this problem at: http://digital.ni.com/public.nsf/websearch/6A1A31BD5EBE484886256E85005CE553?OpenDocument
It seems as though you are going to need a clever workaround, or need to include the diagram with LabVIEW version 7.0...
Travis M
Applications Engineer
Travis M
LabVIEW R&D
Message 6 of 8
(2,690 Views)
Thanks Travis.
That link does explain the problem. It seems that I need to upgrade to 7.1. The 7.0 solutions are impractical.
For the time being I am moving back to 6.1. Which works just fine.
Message 7 of 8
(2,670 Views)
The solution you propose is too painful. I am reverting to 6.1. I will get 7.1 when I can justify it.
Thanks for the help.
Message 8 of 8
(2,669 Views)
