Showing results forΒ
Search instead forΒ
Did you mean:Β
Keyboard Controls
Hi. I just started using LabVIEW and I am currently using NI LabVIEW 2013 to control a quadcopter by using keyboard. I can only use certain buttons on my keyboard to toggle the buttons. Is there a way for me to for example use letters "w/a/s/d" to control my buttons?
Thank you πŸ™‚
Message 1 of 14
(2,863 Views)
Use an event structure to detect the Key down and key up events.  Look at what key is pressed by the event data node inside the event case.
Message 2 of 14
(2,854 Views)
Sorry I forgot to attach what I've done
Message 3 of 14
(2,850 Views)
-Also you can try the example provided along with labview for keyboard events.
Go to Help>>Find Examples>>Search for Keyboard.
-Can you post your vi in lv12 (File>>Save for Previous version) because i cannot open your vi.
uday
Message 4 of 14
(2,830 Views)
I found the example but I think it wasn't useful for me.. I've attached my vi for lv12.
Thanks! XD
Message 5 of 14
(2,817 Views)
Accepted by topic author makewayforkhairil
Example for getting the keys pressed with events.
Message 6 of 14
(2,809 Views)
Use Raloks event structure, then just add a case structure for the different keys.
Remember chars are: w,s,d,f,g,h,j,k,l...............
vkeys are: Up, Down, Ctrl, Return...............
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 7 of 14
(2,785 Views)
Please keep timeout for event structure, otherwise when no key is pressed and you try to stop the vi, it will not stop.
uday
Message 8 of 14
(2,767 Views)
Ideally, the Stop button should have a value change event case in the structure to handle that.
Message 9 of 14
(2,746 Views)
Hey I was wondering where can I get the circled symbol? XD
Message 10 of 14
(2,716 Views)
