04-16-2019 01:04 AM
Hello LabVIEW Users,
I am working on the Hungarian language based application and having trouble in two characters which are not recognized by LabVIEW as well as SQL Server2008.
Characters are ő and ű.
For more information, l have attached document here which shows that how LabVIEW and database recognize it.
Thanks ...
04-16-2019 08:09 AM
I suspect this is a "Unicode in LabVIEW" issue. If you do a Web search on this topic, you can see the current state of this issue.
04-16-2019 12:39 PM
04-17-2019 12:17 AM
I am able to show characters in LabVIEW but not able to show(log) it into SQL server database.
Please see the attached image for more information.
04-17-2019 12:18 AM
But manually I can write those characters in database ,but can't write it through LabVIEW
04-17-2019 03:46 AM
Have you tried to change ist to utf8 before writing it to the DB? If reading it from the DB you have to change it back. For conversion there is a hidden LV function. Have a closer look here:
04-17-2019 08:32 AM
This is a cool function if you want to write special characters like Ő as an utf-8 string to a text-file
but does piZviZ's SQL 2008 database accept utf-8, or rather UTF-16 encoded strings?
04-17-2019 11:17 PM
Can you upload same VI? I am not able to use snippet.
04-18-2019 12:34 AM
Download is in the link I've sent.
A more detailed description can be found here:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Unicode-Programming-Tools/ta-p/3493021
04-18-2019 07:21 AM - edited 04-18-2019 07:23 AM
are a different resource (in regards to undocumented function "text to utf-8").
also, its a good resource to learn about unicode-specific tidbits (that may bite you) like utf16-LE and BOM
