Is dalsa falcon 04M60 compatible with PCIe1477?
I connect the camera dalsa PT-41-04M60-05E to NI FPGA PCIe1477 with camera link, I could not find this camera in NIMAX (I can only find PCIe1477). I have installed LabVIEW, FPGA Module, VAS, version 2020, 32 bit. Should I install some other drivers?  Or are they compatible?
Thanks for your help,
Ran
(789 Views)
I put NIMAX capture here
(786 Views)
I have not used the 1477 but as an FPGA.  Maybe if you run the camera and the shipping examples you will see it send data back to the computer?
ALE Consultants
(726 Views)
I have used this 1477 as an FPGA (not connected to a camera and no acquisition), it works well. But when I connected to the camera dalsa falcon 04M60 I could not find it.
I try to execute the getting started NI 1477 acquisition example, but I receive this error :
Error -8999 occurred at Acquisition initialization: this error typically occurs when a camera is not properly connected, is not powered, or is not the correct type.
Hope for some ideas, thanks.
(720 Views)
