Here is the install.bat file we made to do this. Keep in mind, this just “appears” to install everything listed in it correctly as a clean install. Proton is our network drive.
@Echo Off
@Echo Starting Labview 8.2 Installation
\\Proton\LoginUpdates\LV-10-06\LV8.2\setup.exe \\Proton\LoginUpdates\LV-10-06\LV8.2\Bin\NoUser.txt /r:n /q /AcceptLicenses yes
@Echo Starting CVI 8.0.1 Installation
\\Proton\LoginUpdates\LV-10-06\CVI8.0.1\setup.exe \\Proton\LoginUpdates\LV-10-06\CVI8.0.1\support\NoUser.txt /r:n /q /AcceptLicenses yes
@Echo Starting Signal Express 1.1.1 Installation
\\Proton\LoginUpdates\LV-10-06\SignalExpress1.1.1\setup.exe \\Proton\LoginUpdates\LV-10-06\SignalExpress1.1.1\Bin\NoUser.txt /r:n /q
@Echo Starting Toolkit Installations
@Echo ---- Starting Advanced Signal Processing
\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Advanced Signal Processing\setup.exe" "\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Advanced Signal Processing\supportfiles\NoUser.txt" /q /r:n
@Echo ---- Starting Digital Filter Design
\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Digital Filter Design\setup.exe" "\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Digital Filter Design\supportfiles\NoUser.txt" /r:n /q
@Echo ---- Starting Database Connectivity
\\proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Enterprise\Database Connectivity\Setup\lv_dbtools.msi" /passive /norestart
@Echo ---- Starting Internet kit
\\proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Enterprise\Internet\InternetToolkit6.0.msi" /passive /norestart
Echo **** Labview SPC Toolkit can not be installed silently ****
Echo **** You will need to install manually ****
@Echo ---- Starting Express VI Development
\\proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Express VI Development\ExpressVIDev\ExpressVIDev.msi" /passive /norestart
@Echo ---- Starting PID Control
\\proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\PID Control\setup\lv_pid_6.msi" /passive /norestart
@Echo ---- Starting Report Generator
\\proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\Report Generation\lvoffice\lvoffice.msi" /passive /norestart
@Echo ---- Starting State Diagram
\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\State Diagram\StateDiagTK.msi" /passive /norestart
@Echo ---- Starting VI Analyzer
\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabVIEW\VI Analyzer\setup.exe" /q /r:n
Echo **** CVI SPC Toolkit can not be installed silently ****
@Echo ---- Starting SQL Kit
\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabWindows CVI\Enterprise\SQL\Sql2.msi" /passive /norestart
@Echo ---- Starting PID for CVI
"\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabWindows CVI\PID Control\setup.exe" /q /r:n /AcceptLicenses yes
@Echo ---- Starting Signal Processing for CVI
"\\Proton\LoginUpdates\LV-10-06\ToolKitSoftware\LabWindows CVI\Signal Processing\Setup.exe" /passive /norestart
@Echo Toolkit Installations Completed... Please install manual components.
@Echo Starting NIDaq 8.3, NIMotion 7.4, NIVisa 4, etc... Installation
\\Proton\LoginUpdates\LV-10-06\DCD-Nov06-1\setup.exe \\Proton\LoginUpdates\LV-10-06\DCD-Nov06-1\spec.ini /r:n /q /AcceptLicenses yes
@Echo Installation Complete......
Now this took us weeks to make. Notice you have three different types of installers with different command line switches. there isn't even a set of NI standards. It took us a long, long time to put this together, trying an install and wiping the PC clean over and over and over until we finally came up with this...
So my question is, are you guys sure it was such a good idea not to use a standard MSI file? You really need the NI custom installer with non-group-policy-compatible msi's?
If you gave us real msi files this could have been much easier!
Message Edited by billings11 on 10-09-2007 02:17 PM
-Devin
I got 99 problems but 8.6 ain't one.
